1984 OLDS cutlass supreme
Old Nov 3, 2004 | 11:44 AM
TRANSAMCHARGER's Avatar
Default 1984 OLDS cutlass supreme
I was just wondering what modifications i would have to make to this car to put in a ls1, lt1 or grand national motor in it or can i simply turbo it. Would i need to change the motor to carberated, change transmissions and rear end any thing else?
thanks
Old Nov 3, 2004 | 12:26 PM
or could i just replace the 6 cyl with a gm crate 350 motor, it says it puts out 260 hp and it runs for $2000.
Would i need a new tranny and rear end or anything else for this swap? Also would it get better gas mileage then the 6 cyl? Sounds stupid but the 3.8 only gets 16 miles to the gallon.
or is there a way to turbo my existing motor?
any info. is helpful
thanks
Old Nov 4, 2004 | 02:20 PM
Kevin Winstead's Avatar
Here's one option. Check out my website.
www.geocities.com/bad79z28/cutlass.html
An LT1 would be another alternative. It would drop right in...just use the Monte SS engine mounts.
If you go with an LS1 check out John's site.
http://home.earthlink.net/~bzdel/
In either case you can contact Speartech for your wiring harness and ECU needs and me for your transmission and torque converter needs.
kevin@tciauto.com
Kevin
thanks
