clutch master cyl for a 64 pickup
Old Nov 22, 2004 | 12:58 AM
64c10ls1's Avatar
Default clutch master cyl for a 64 pickup
Can I use the stock clutch master cylinder out of a 60-61 c10 pickup and hook it up to a 98 ls1 M6 slave cylinder?? Can I some how splice the hoses together or get the right ends? Will it have enough volume or pressure to properly release the clutch?
Thanks
Old Nov 22, 2004 | 07:56 AM
Project GatTagO's Avatar
Do you know the specs of the stock MC? Bore size? Stroke? I am using a 3/4 US Brake MC in my Mazda and it works perfectly.
Andrew
Old Nov 22, 2004 | 01:40 PM
seadog's Avatar
i am using a stock mc from an 89 s-10 and it works fine. you need to know bore and stroke though. as far as connecting lines goes, i used a couple of adapters to screw into the mc and convert to -4(I think it was -4) an line. that is what comes off the slave cylinder, which is also teflon lined. cut it where i wanted it and connected.
Old Nov 22, 2004 | 02:57 PM
DaleMX's Avatar
I just ordered a Wilwood 3/4 X 1.1 stroke MC for mine. 63 bucks at Jeg's.
