wiring harness/tranny question
Old Dec 3, 2004 | 10:29 AM
LS69TA's Avatar
Default wiring harness/tranny question
I got my modified harness for the motor, and was mocking it up on the engine, and there is nothing that goes to the tranny. Does anyone make a harness just for the 6spd, or how should I go about this. I'm kinda lost at the moment.
Old Dec 3, 2004 | 09:43 PM
onehardmaro's Avatar
Not sure about getting the harness for just the transmission; think you need the whole engine harness. But you can still drive with out the harness; just will not have skip shift, a good thing, or reverse lock out, probably not a good thing.
Old Dec 3, 2004 | 10:18 PM
LS69TA's Avatar
Ok. I can live with that. I hate the skip shift. I'd have to try realllly hard to put it in reverse while going through the gears.
Old Dec 3, 2004 | 10:43 PM
patrick_rodgers's Avatar
There should be a VSS (Vehicle Speed Sensor) feed from the transmission to the computer, so it knows if the car is moving or not. Also, there will be the reverse light switch.
