Abs
Old Dec 7, 2004 | 10:16 PM
BizZzatch350's Avatar
Moderator
Default Abs
If you were to say put an LS1 in to an LT1 car, would the abs from the LT1 still work?
Old Dec 7, 2004 | 10:29 PM
boondiggys's Avatar
they say you would need to update the abs pump from a newer car to go with the new engine harness. is the plug the same?
Old Dec 7, 2004 | 11:51 PM
Moderator
Not sure at all, thats why I'm asking.
Old Dec 10, 2004 | 12:42 AM
boondiggys's Avatar
id talk to speartech about it they for sure would know
Old Dec 10, 2004 | 02:39 PM
01WS6/tamu's Avatar
You would just have to get a abs pinout for your car. Then decipher the what connections the ls1 harness has for the abs and wire the connections to your existing abs. It also depends on if your car has traction control. If not then the lt1 system is pretty simple.It receives front wheel speed inputs from the wheel speed sensors and rear input from rear sensors.appropriate 12 v cns, 12v ign, ground, and brake switch,and input class 2 communications buss if 96' up. 60A fused input to run the pump motor and that is it. The system with traction control adds a few more inputs and the throttle kicker motor. It also works in conjunction with the pcm.
