Running no fuel level signal
Old Dec 14, 2004 | 03:43 AM
Payne's Avatar
Default Running no fuel level signal
What happens if I dont run a fuel level to the PCM? Does the PCM go into lump home mode without a signal?
I need to use those wires for my RX fuel signal so I know how much gas I have left...
Old Dec 14, 2004 | 05:55 AM
pjtimmer's Avatar
I thought the pcm didn't need those wires, it is only for gaugepanel i think, now I am not sure though...
Peter
Old Dec 14, 2004 | 07:49 AM
crainholio's Avatar
I just ran this whole season with no fuel level signal on the bus. In fact, I don't even recall seeing a pin on the PCM for that input.
Either way, the PCM was a happy camper without it.
Old Dec 14, 2004 | 01:49 PM
Payne's Avatar
I have heard that the computer needs the fuel level for EVAP stuff, as well as to prevent a limp home mode (fuel efficient) I have no idea if this is true or not...
Old Dec 14, 2004 | 03:10 PM
GTS346's Avatar
Havent heard that before.
I dont no of any conversion LS1's which run the factory sender unit.
Old Dec 19, 2004 | 01:07 PM
Payne's Avatar
On the red PCM connector it is pin 54, so yes, the PCM sees the fuel level.
What does it need it for?
Old Dec 19, 2004 | 03:12 PM
badjuju342's Avatar
Deranged Rat Fink
The guage cluster wiring is serial data fed , it's not straight from the engine sensors.
