LS1 in RX7
Old Jan 24, 2005 | 09:41 AM
RFERG43's Avatar
Default LS1 in RX7
I'm doing the wiring in my conversion now. I discovered a small (about 1/8 inch) black tube with a right ange rubber connector on it coming out of the main harness. It disappears behind the center rear of the engine. I can't see where it goes but I can blow air through it. Can anyone tell me what it is and what to do with it?
Old Jan 24, 2005 | 10:32 AM
Dave_62's Avatar
It's a vacuum feed for the HVAC mode doors inside the car. It's a manifold sourced vacuum, so if you don't need it for your application, it should be capped.
Old Jan 24, 2005 | 11:37 AM
DanZ28's Avatar
What he said ^^^^^
