ls1/t56 first gen swap.....
I am planning a ls1/t56 swap into my 68 camaro for next winter, as it seems that a ton of swaps are in the works from lack of planning, i would like to plan everything just right.
Heres my plan so far:
-Buy a wrecked 98-02 camaro with ls1 and t56 (also using seats rear brakes etc.)
-fabricating motor mount brackets
-wiring harness
-high pressure feul pump
-feul return line
-reprogram ecm
-fabricating air intake
-rework the oil pan
-ats t56 install kit
I'm sure im missing a ton there, also as you can see i prefer to do things myself.
Also if i were to buy the whole 4th gen camaro, would I be able to take the pedals out of it and swap them in, and the booster and master.
The big things I still need to work out:
-gauges
-exhaust
-fittings for ps
-everything i cant think of
I know a ton of you guys have done theese and I appreciate you humoring me. Also take a look at my webpage on my sig its nothin special but more than most 17 year olds can build.
Thanks
Brian
-wiring harness
-feul return line
-reprogram ecm
-rework the oil pan
-gauges
-exhaust
-fittings for ps
Thanks
Brian
You can use the front brakes as well. When you get started drop me a line and I will hook you up with pics of anything that you will encounter.
fred
skinner@srcaccess.net
