few questions on astro vans
Old Feb 14, 2005 | 04:41 PM
NOTFAST's Avatar
Default few questions on astro vans
just got through reading up on the ease of the ls1/v8 astro van conversions now i got a few questions
it seems as if there are awd and rwd astros? is this correct?
also, would the ls1/ls1 bolt right up to the stock 4.3L motor mounts? or do you need extra mounts...same with tranny...
seems like a straight forwards swap if that can be said about any swap
Old Feb 14, 2005 | 06:29 PM
01WS6/tamu's Avatar
You need to get an adaptor kit for the motor mounts. The transmission is the same though.
Old Feb 23, 2005 | 11:08 PM
UJSLOST's Avatar
Look on ASTROSAFARI.COM. They might have what you need. Hope that helped !!!
Old Feb 24, 2005 | 12:21 PM
astross's Avatar
1. SBC V8 swap to Astro is easy (I have made), you only need custom engine mounting brackets.
Engine is bolt- on to gearbox
2. Lt1 swap to Astro ,same as SBC swap, you can use normal SBC V8 swap engine brackets.
Engine is bolt on to gearbox
3. LS1 swap is little more complicated.
Ls1 engine use the same gearbox bolt pattern like V6 and SBC V8, they are bolt-ons.
Engine mounting brackets are totally different to compare it to SBC, you have to make a custom brakets.
If you want more information visit our (Astro/Safari) forum ; http://www.astrosafari.com
There is 3 guys who have made LS1 swap.
My Ls1 swap(truck 5.3) is currently on progress.
If you want more info, send me PM.
edit: here is link to one LS1 powered Astro page : http://www.aei.ca/~nmaclennan/
Old Feb 24, 2005 | 12:33 PM
'JustDreamin''s Avatar
Yes, there are RWD and also AWD Astro's and Safari's (GMC brand). Front axle assembly is very similar (although I'm not sure if they're an exact duplicate / interchange of the S10 parts)
'Dreamin'
Old Feb 24, 2005 | 03:49 PM
CMcCarthy's Avatar
astrosafari.com is a HUGE treasure trove of info concerning swaps like this. I suggest you join up and start posting over there too. An LS1 in an AWD astro would be downright sick. It uses the same transfer case and differentials as a Syclone, you know.
