couple of swap questions
The second question I had was, has anybody put an older style gm standard with a old style clutch behind an LS1? I'm putting an sm420 behind it hopefully if I can get it all worked out. I'm not sure if the LS1 fbody or vette flywheel will do what I want or not.
If anybody has any info I would sure appreciate the help.
Start here. Then here. Then here.
Those threads contain much of the same information, although together I think they give the whole story. It looks like all you have to do is call Lakewood and they can get you what you need.
I'm not sure how to tell a 4.8 from a 5.3. You might try posting the question in the truck section. The 5.3 in my Silverado hauls my car with ease, so it should do well in a Scout.
