LS1 spotters guide
Old Mar 30, 2005 | 12:28 PM
Slipstream's Avatar
Default LS1 spotters guide
Can someone point me to a thread or other info that will allow me to tell the different LSx engines apart? I will be shopping for a LS1 soon and need to read up on the different versions.
I searched through over 400 threads so please don't tell me to use the search button!
Old Mar 30, 2005 | 03:37 PM
Project GatTagO's Avatar
Vette engines are easy to spot. They have the alternator high on the drivers side and use a drive by wire throttle body (no cable). F-body engines are also easy to sopt, they have have the alternator low on the drivers side and a cable actuated throttle body. Truck engine have a very different looking manifold, very tall, compared to F-bodies and Corvettes. The alternators on truck engine are mounted very high and on the drivers side (I think).
That will get you started. There are a ton of other subtle differences.
Andrew
Old Mar 30, 2005 | 08:05 PM
Stu Cool's Avatar
Reading here helped me a lot...
https://ls1tech.com/forums/showpost....80&postcount=2
Old Mar 30, 2005 | 08:32 PM
Nine Ball's Avatar
LS1Tech Co-Founder
97-98 LS1s have valve covers with bolts going around their outside perimeter. The 99-04 LS1s have only four valve cover bolts, down the center of them.
Thats the main difference, since the heads are different. The later type is more desirable of course.
