Brake Servo connection to LS
Old Apr 6, 2005 | 08:58 AM
jellison's Avatar
Default Brake Servo connection to LS
Hi - I am just about to put my LS6 in to a TVR. This has two hoses for the brake servo (in / out?) that I need to connect up to the engine to get the assistance for the brakes.
Where should I connect these onto the LS engine (exhausts - don'y had std ones - Headers) or Inlet? is there some in / out ports that these connect to
Old Apr 7, 2005 | 01:59 AM
jellison's Avatar
Someone must know two to connect up the Brake Servo pipes to an LS!?
Old Apr 7, 2005 | 04:04 AM
DaddySS's Avatar
Not sure why there would be two - one vacuum and one air intake probably. If so, the vacuum goes to large connector at the back of the intake and the air supply you can attach to any air filter source or just add a small filter to a section of hose.
Old Apr 7, 2005 | 08:38 AM
jellison's Avatar
Cheers for that - by the air filter source do you mean attach it to the inlet tract running to the MAF?
Old Apr 8, 2005 | 09:14 PM
WILWAXU's Avatar
Let try this one in our Hybrid section.
Old Apr 8, 2005 | 10:19 PM
Earl Filter's Avatar
Going out on a limb here, I believe he means to attach a separate small air filter to the hose. I would think something like a breather filter. Just as an example...
http://www.knfilters.com/vent.htm
Old Apr 9, 2005 | 04:20 PM
stevieturbo's Avatar
Jellison. I would be more inclined to ask fellow TVR owners why there are 2 pipes for the servo. Usually there is only one vacuum source thats required, which you will find the takeoff for at the rear of the inlet manifold.
Does your car use a remote Servo ?? Is there perhaps 2 servos in there ??
Try sucking them....a pipe that attaches to a servo is basically a pipe into a closed chamber.
I actually started my engine today !!!!!!!!! It only had headers on it, so was a bit loud lol...
Still a few problems to sort, and it will be driving again.
Or indeed if you could get another pic, showing where those pipes attached on the old Rover engine.....
