1972 monte carlo swap
Old Apr 6, 2005 | 09:33 PM
72 golden brown's Avatar
Default 1972 monte carlo swap
I am planning to swap a Gen III engine into my 1972 monte carlo. I am debating between an LS1 or an LQ9 crate motor. The LQ9 is listed as having 345 horsepower out of the crate while the LS1 has 320. Also the LQ9 is much less expensive. Is there any reason to go for the LS1 other than the fact it weighs about 100 pounds less? Especially since all the parts for these engines are interchangeable and I could put the money I save by getting an LQ9 into new heads and a hot cam. Any advice would be greatly appreciated!
Old Apr 7, 2005 | 05:48 AM
72ChevelleConv.LS1's Avatar
A lot of people build the 6.0 it is a good choice. just the weight is the main reason. Check with Shaun at SMC performance for your motor, he has some 6.0 and LS1 stuff. valvegod@aol.com he is a great source for stuff.
Old Apr 7, 2005 | 06:35 AM
L-EATER's Avatar
11 Second Truck Club
It would be nice to save the weight, but for the price the LS1's are bringing, I would go with the 6 liter. You could even turn a 5.3 into an iron LS1 for cheap.
Old Apr 7, 2005 | 07:47 AM
Project GatTagO's Avatar
Your going to have about 3 feet between the engine and radiator in a Monte. Get the 6.0 and save up for a turbo. You will have a TON of room.
Andrew
