fueling help please
Old Apr 16, 2005 | 02:20 PM
Blase4x4's Avatar
Default fueling help please
I started my gen3 swap for the first time yesterday and it ran beautiful for all of about ten seconds. After that i could tell it was dumping fuel at an alarming rate. I took it to a local repair shop to have them scan it only to have them tell me that the fuel trim is running at a negative 25 to 30 and the o2 sensors are telling it that it's rich(900)! After doing some testing this moring i found that the motor runs better if i unplug the o2 sensors. I was told that maybe, my so for painful wiring harness may have the rich and lean o2 wires switched around. Does anyone have a computer conector diagram? I did not know about this web site or speartech when i started my swap, but i would not recomend useing a painless wiring harness!!! Any help would be appreceated. I am leaving on the 20th to go on a trip need to fix this problem are cancel my trip. thank you
Old Apr 18, 2005 | 02:16 PM
StngKlr's Avatar
I seriously doubt it has anything to do with wiring. Have you put a fuel pressure gauge on there to check what psi its running at? Also, what did you use for a fuel system? Check the psi and lets go from there.
