LS1 into a cutlass supreme?
Old Apr 18, 2005 | 02:39 PM
ayalam's Avatar
Default LS1 into a cutlass supreme?
So After I get the engines where do i begin? who sells mounts for such a project. Good places to buy an engine?
Old Apr 18, 2005 | 02:54 PM
Earl Filter's Avatar
A Cutlass would be the same as a Monte Carlo (a G-body). John B here on the forum sells mounts, and you need a trans crossmember for the 4L60e, assuming you are going with an automatic. Search for Monte Carlo within the Conversions section, and you'll find plenty of info.
Old Apr 18, 2005 | 03:29 PM
Mark IXZD 150's Avatar
Pretty much every question you may have has already been asked and answered here. LS1tech.com should be your first source to search on any question.
Good luck! A Cutlass (especially a 442 or Hurst/Olds) would be wicked cool with an LS1 engine in it.
Old Apr 18, 2005 | 07:27 PM
ayalam's Avatar
thanks someone told me it was an A body, same as a chevelle. I guess i'll search a little more. But if u guys have any ideas let me know.
Old Apr 18, 2005 | 07:38 PM
What year is the car? If it's a '70 Cutlass, then it's an A-body. If it's an '86 Cutlass, it's a G-body. This will make a big difference.
Old Apr 18, 2005 | 09:22 PM
ls1_chevelle's Avatar
I was the one that called it an A-body. The car in question is a 71 which I'm positive is an A-Body car.
-Matt
Old Apr 19, 2005 | 06:49 AM
-Matt
For some reason, I had my mind on the G-bodies, and didn't consider that it was older. You're right.
Old Apr 19, 2005 | 01:16 PM
John B's Avatar
Moderator
Welcome aboard! The 78-81's are called "A" and the '82 thru '88 are "G" Bodies.
Try this link for a complete rundown on the swap you're after http://www.montecarloss.com/ls1montecarloss/
Let me know if you'd like a bolt-in set of motor mounts & oil pan!
Old Apr 19, 2005 | 04:44 PM
Originally Posted by John B
Welcome aboard! The 78-81's are called "A" and the '82 thru '88 are "G" Bodies...
The '64-'77 would be the "old" A-body as well, right? Cutlass/442, Chevelle, Skylark etc. is what I'm thinking...
