PCM Mounting
Old Apr 27, 2005 | 01:30 PM
redmist's Avatar
Default PCM Mounting
Has anyone come up with a clever way to mount a 1998 PCM? Does the PCM need to be insulated from the frame?
Old Apr 27, 2005 | 02:05 PM
LS1Sandrail's Avatar
I made a bracket out of 2" wide strap and bolted it onto the tube chassis of my sandrail and it works fine. It clamps the PCM arount the parting line and holds it it place. It sees a lot of shock and vibration and does fine. PM me and I'll send you a picture if you want to see it
Old Apr 27, 2005 | 02:39 PM
MrDude_1's Avatar
the PCM does NOT have to be insulated... matter of fact, internal to the case, its grounded using ground wires going into it...
Old Apr 28, 2005 | 10:14 AM
redmist's Avatar
Default Thanks All!
That's the info I needed.
