LSx swap help with th350
Old May 4, 2005 | 08:12 PM
TJ's Avatar
TJ
Default LSx swap help with th350
2004 6.0L
motor was pulled from a truck with a 4L80, so the crank spacer is already attached.
its behind the flywheel, which id assume was correct, tho i have seen pics where people put it on in front of the flywheel. guess that depends on what flywheel you use?
my problem is the converter has no ajustment when bolted up to the flywheel.
it bottoms out on the front pump. no room at all to slide the converter back and forth between the tranny and flexplate.
the only thing i can think of is running a 1/8 spacer between the bellhousing and the block, similar to a BOP adapter.
im lost.
i can snug all the bellhousing bolts with my fingers, and the converter will still spin freely. one touch with a ratchet and the converter bottoms out on the crank spacer and the front pump and wont turn.
any suggestions?
thanks in advance.
Old May 4, 2005 | 08:52 PM
strokedls1's Avatar
You don't need to run the spacer at all. Are you using a TCI flexplate? Bolt the flexplate in without the spacer and try it out.
Old May 4, 2005 | 09:20 PM
TJ's Avatar
TJ
stock untouched parts.
6.0L flexplate, crank spacer. came on the motor pulled from the truck in the junkyard.
