Engine Harness Question.
Old May 4, 2005 | 10:14 PM
69cam's Avatar
Default Engine Harness Question.
I'm In Process of Find A 98 harness for the 98 PCM I got. I have never seen the Harness so im unsure what it looks like. Are both of the PCM Connectors (Blue/Red) part of the engine Harness? Or is one of the Connectors for the engine and the other for the Car harness? Thanks
Old May 4, 2005 | 10:17 PM
Nine Ball's Avatar
LS1Tech Co-Founder
both are for the engine controls and gauges. No car body functions on there.
Old May 5, 2005 | 07:51 AM
SatisTraction's Avatar
you should serously consider upgrading to a 99 or newer harness and computer. there just is not much suport out there for a 98 model. read back a coupld of days and you will see a post concerning this.
chris
Old May 5, 2005 | 08:12 AM
MrDude_1's Avatar
they're both on the engine harness..
the engine harness will have:
all of the engine and trans connectors
the two PCM connectors
3 underhood metripack connectors not connected to anything
2 connectors that used to go underdash to the BCM
1 big purple wire that goes to the starter 'noid
