lt1 wiring
Old May 12, 2005 | 08:21 PM
lt99s10's Avatar
Default lt1 wiring
im putting an lt1 in a s10 wanted 2 know if anyone has ever modified a stock harness to run motor only found a guy in florida 2 do it for 350
Old May 12, 2005 | 08:22 PM
Aries's Avatar
it can be done fairly simply. Main thing is the vats bypass.
Old May 13, 2005 | 10:25 PM
Klortho's Avatar
If you don't want to tackle the harness yourself, goto http://www.lt1350.com he modifies the harnesses.
Old May 13, 2005 | 11:07 PM
LTCobra's Avatar
I too want to do the same thing. Are there any instructions online to do this myself?
Old May 14, 2005 | 08:55 AM
Klortho's Avatar
There is alot of info on Thirdgen.org on wiring, they probably won't answer questions since the engine isn't going into a thirdgen f-body car but some good posts.. http://www.thirdgen.org/techbb2 and go under the engine swap forum
