No spark????
Old Jun 7, 2005 | 11:56 PM
SICMARO's Avatar
Default No spark????
We have ign power at the coil harness and at each coil, but when cranking motor we get no spark? HELP any ideas?
Old Jun 8, 2005 | 12:26 AM
SatisTraction's Avatar
crank trigger
Old Jun 8, 2005 | 12:29 AM
SICMARO's Avatar
Someone has cut and spliced a new connector on to my crank shaft position sensor. there are a yellow (pin 44 Red plug) yellow w/black (pin 22 blue plug) and green (pin 62 blue plug) they have each been connected to a dark blue aftermarket wire that plugs into the crank positon sensor! is this ok? i know your not susposed to mod o2 sensor wires could this be my problem?
Old Jun 8, 2005 | 01:42 AM
I think you need a complete wiring diagram to sort that thing out. there is no way anyone on this board will know how to assist you with a harness that is that modified.
the O2 harness will have nothing to do with it not getting a spark. if it the coild have power, the VATS is removed, and the trigger is working you should have spark.
Old Jun 8, 2005 | 02:15 AM
ls1canuck's Avatar
When I tried to fire mine for the first time, I had power everywhere but it wouldn't start, just like yours. So I ran a line direct from the battery to the computer instead of through the ign. switch. She fired right up. I just simply didn't have a strong enough power source. After that I added a new ignition relay and it runs great. This may not be the problem, but you might as well start with the easy stuff.
