SPEARTECH wiring question
Old Jun 19, 2005 | 11:58 AM
93LS1RX7's Avatar
Default SPEARTECH wiring question
I have pulled my harness out of the car and I didnt mark the wires.
What are the Thick pink
White w/black strip
Orange
Yellow
I think Pink is the power for the PCM
White/Blk is the tach signal
Finally when I wire the starter to the switch is it just a one wire to it and that is it? I did it before but I forget how I had it.
Mike
Old Jun 19, 2005 | 12:34 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Pink goes to your ignition switch (12 volts with key on and during crank)
Orange goes to the Battery (12 volts at all times)
White is the tach signal out
Yellow is the speedometer signal out
For the starter it's just one wire from your ignition switch to the small solenoid terminal (12 volts during crank)
...and of course your positive battery cable to the large post on the solenoid.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jun 19, 2005 | 01:17 PM
93LS1RX7's Avatar
John
Thanks a ton for your quick response. You guys are top notch.
Ok the orange is the hot for some reason I thought the pink was hot. Too easy you the man!!
Mike
Old Jun 19, 2005 | 01:48 PM
93LS1RX7's Avatar
The switched 12V to the starter is prewired in your harness right. It is the hole terminal that is wrapped in aluminum heat shielding?
Old Jun 19, 2005 | 02:08 PM
Speartech's Avatar
Yes, but it is up to you to get ahold of the other end of that wire (purple) and hook it to your ignition switch.
__________________
www.speartech.com
Old Jun 19, 2005 | 03:32 PM
93LS1RX7's Avatar
gotcha the purple wire with the single water tight connector.
