LS1 in 69' Camaro Help...
Looking to do a LS1 drop into a 1969 Camaro SS. I am currently working out a deal for a 98 LS1 out of a Camaro. My question is this...when I build it up, I will be switching the 1998 motor into my 2002 Camaro SS and then transplanting the motor from the 2002 into the 69 and I just want that as my baby. Will I run into any problems with putting the 1998 motor in my 2002? I know it sounds dumb but as of right now, I'm just confused!
P.S. In the 69, I will be using the LS1 Carb set-up from MSD and Edelbrock so the PCM from the donor Camaro will not have to be used for the 69' and will be non existant.
Am I getting that right?
Basically:
1. Can I use the 1998 engine with my 2002 PCM?
2. Just making sure the LS1 Carb Set-up will be cool with no PCM in the 69'?
Help guys!
