fuel system
Old Jun 25, 2005 | 11:14 AM
1971ssLS1's Avatar
Default fuel system
i already own an aeromotive AFPR, inststead of going to route of using the vette filter/reg, or mounting the AFPR way up front, couldn't i just mount it in the back and use a short return, basically the same setup as the vet, but adjustable, correct???
Old Jun 25, 2005 | 09:04 PM
GTS346's Avatar
Wont hurt to give it a try, if you can maintain pressure from idle to WOT your fine.
If it works it works, if it doesnt then go from there.
Old Jun 27, 2005 | 09:41 AM
MrDude_1's Avatar
yes, you can do it that way. just be aware that theres alot of road grime thrown up back there, but the FPR nipple must be open to the atmosphere... i would put a piece of foam over the nipple... something like a nitro RC airfilter would probly work great.. lol
Old Jun 27, 2005 | 10:41 AM
redmist's Avatar
Default Junk in the trunk
I did exactly that. Put everything in the trunk spare tire well, including the fuel pump, with a very short return line from the regulator back to the fuel cell.
