Instrument Cluster
Old Jun 25, 2005 | 07:22 PM
RestoVette63's Avatar
Question Instrument Cluster
Anybody hooked up the odometer/trip calc/milage calc functions incorportated in the LS1/2 computer from a Vette or GTO?
I would like continue to use these functions on my conversion but don't want to transplant the entire cluster.
Thanks,
J
Old Jan 31, 2012 | 10:44 PM
Laredo1's Avatar
Default Same Cluster Question
I have a 1982 Jeep CJ7 ...have a 2002 LS1 with 4L60E I am Transplanting into jeep...It came with Pedal assembly, Fuel Pump, ECM, and Fully Dressed. I then bought the Original Instrument Cluster and Hoped someone had some direction of a place to start. I have read threads converting to aftermarket guages...just needed a starting point to use this original Cluster.
Old Jan 31, 2012 | 11:19 PM
spacemanspif's Avatar
Talk about bringing a post back from the dead!!! 2005, wow.
To hook up the stock cluster you should just need to run the factory wires to it. Might need to incorporate a BCM or other control module though depending on how each car is wired from the factory.
Old Jan 31, 2012 | 11:44 PM
the_merv's Avatar
Veteran: Air Force
Depends if it's Analog or Digital..that is probably what the guy is referring to.
