how to wire a 01-02 corvette alt
10436674 best I can tell this is for a 01-02 corvette. Anybody know if the 98 alt and the 01-02 alt are wired the same? I am using a stand alone TECIII computer. Looking at the below picture my 98 is wired like this.
#3 is hooked up to a resister (2- 1000 ohm 1/2 watt resistors in parallel) and switch 12 volts.
#2 is hooked directly to switched 12 volts.
I wired the 01-02 the same way but the l0 amp fuse that is on the line for #2 + #3 blew the first time I took the car out. This same wire also powers my holley red pump, so blowing the fuse is no fun. Somebody help I don't want to drive the car until I solve this issue.
Thanks,
mark
