Wiring help 04 GTO
Old Jul 14, 2005 | 05:35 PM
ls1chevy2's Avatar
Default Wiring help 04 GTO
I need some wiring help.
I bought a full pull out from fparts.
This is a LS1 T56
I'm putting this in a 66 nova.
I'm using the the GTO stock gauges stock fuel pump and sender the pcm and ecu.
Should I go with painless wiring?
Or just order the stock wiring harness it's hundred buck less?
The 1 inch by 2 inch plug that I think plugs into the fuse box
I need some kind of wiring diagram that lets me know what each of them does.
Old Jul 14, 2005 | 06:39 PM
crainholio's Avatar
Nice swap package and target!!
Don't go w/ Painless unless you want to dump the '04 PCM and maybe deal with sensor incompatibilities...the Painless setup is pinned for a '98 F-Body PCM.
There's not been much, if any, GTO action here so you may be blazing a new trail.
Check alldatadiy.com or wherever Alldata is hosted and spend a few dollars on schematic printouts and connector pinout diagrams.
Old Aug 12, 2005 | 10:10 AM
stan_the_man's Avatar
I PUT A 99 LS1 IN 66NOVA AND USED THE GM WIRING IT,S EZ IF YOU STILL NEED HELP E-MAIL AT STAN_THE_MAN70@YAHOO.COM COOL RIDE FOR A LS1
STANLEY
Old Aug 12, 2005 | 10:43 AM
Jones'n's Avatar
There are a few companies out there that may be able to help you. Speartech has always been great on here. Now I see Speed Scene is aboard, which I have never really heard good things about, but we'll see. Also, Current Performance Wiring is who I have used in the past and they are very reasonable and good to deal with.
