Help with engine parts needed please!
Old Jul 24, 2005 | 03:21 AM
joeclams9's Avatar
Default Help with engine parts needed please!
Here is the long and short of it....
Just getting into this whole LS1/6 fd swap.....dont know all the parts required for a "turnkey engine" for the swap and this is what I have so far:
2A) set of (8) coil packs, (2) coil pack mounting brackets that go on the valve covers, coil pack wiring harness and (8) plug wires for the motor (will work either F-Body/Vette style).
2B) stock water pump for sale (same for both F-Bodies and Corvette's) i
2C) the clutch/flywheel and will put the injectors and fuel rail in the box for no extra if you need them.
2D) stock fuel injectors (28lbs) and an F-Body fuel rail.
LS6 Block
LS6 rotating assembly (Crank/Rods/Pistons/New revised piston rings)
LS6 Heads - #243 Castings complete with valves/springs/rockers/pushrods
LS6 Intake Manifold
LS6 Oil Pump
Double roller timing chain
High Performance MTI Cam
LS6 lifters
Front & Rear Covers
Valve covers
Balancer (Corvette style)
ARP Rod bolts
ARP head studs
New head gaskets
I have an oil pan/sump/pump coming in as well
What else do I need/where to get it, such as pulley package, a/c, alternator..etc.
Thanks
Joe
Old Jul 24, 2005 | 06:57 AM
conan's Avatar
Originally Posted by joeclams9
LS6 Block
LS6 Intake Manifold
LS6 Oil Pump
LS6 lifters
Front & Rear Covers
Valve covers
ARP Rod bolts
ARP head studs
New head gaskets
Joe
Plastic lifter trays
Oil pump O ring
Complete engine gasket kit (I can name most if you need)
knock sensors
oil press sending unit
cam position sensor
crank position sensor
Rear coolant plugs, front cross over pipe (ls6 intake)
Power stering pump (if your runing one)
starter
alternater
idler pullies
throttle body
mass air flow sensor
headers/manifolds
Good luck with you build.
Old Jul 24, 2005 | 09:20 AM
LawmanSS's Avatar
You'll also need a PCM...I didn't see it on your original list.
Most (if not all) of the parts conan listed should be available from a dealer or from KJ at SDPC (sponsor) ----->
http://www.sdpc2000.com/cart.asp?act...tart&catid=873
