ls7 in a 69 Camaro
Old Jul 26, 2005 | 04:41 PM
SLP/Drew's Avatar
Default ls7 in a 69 Camaro
i read an article that had a ls1 in a 69 camaro, it looked bretty sweet...I was wondering if you could drop an LS7 427 in an old model. Haveing a new age 427 in one of those things would be pimp
Old Jul 26, 2005 | 05:24 PM
Rybar's Avatar
All of the neccessary swap parts should be similar, just the wiring, PCM and that throttle-by-wire I am unsure about. Ask John from speartech, he would know for sure.
Old Jul 26, 2005 | 05:39 PM
Steve1969LS1's Avatar
I wish I had an ls1 in a 69.. oh wait.. nevermind..
The hardest part of putting an LS7 into any old car will be the ECM since they are now math based instead of table based.. GMPP will have a solution once the Z06 comes out and they can steal some engineers.. you will also have to fit in a tank for the dry sump system.. other than that its easy since the motor mounts are in the same place as a ls1/6/2
Old Jul 26, 2005 | 06:52 PM
98_Formula's Avatar
i'm sure just about anything can be put in any car with enough fabrication...
Old Jul 27, 2005 | 10:09 AM
ls1_chevelle's Avatar
Its not even the fabrication problem anymore. Like Steve said, Its now tuning is down with Math rather then Tables.... Gm, those bastards!
-Matt
Old Jul 28, 2005 | 02:03 PM
96Z28SS's Avatar
Its still an engine just like any other.
You need to ditch the factory type computer idea and run it on a FAST or Bigstuff3.
Old Jul 28, 2005 | 02:17 PM
sb427f-car's Avatar
SSU'S Vice Mod
Yep, and add a convential wire driven TB, tune away and you're good to go.
