Ready to fire up the LS1 280Z!
- Block off the heater connections on the water pump (broken heater core in car).
- Add oil to the engine.
- Fill the cooling system with Dex.
- Hook up the battery.
- Energize the fuel pump and adjust the pressure.
- Try to start the beast!
http://www.circuitflex.com/ReallyClose.jpg
Silicone hump hoses can be found at www.hightempsilicone.com
or on atp's site too.
J
My only suggestion would be to get/make a strut/stress bar for the shock towers. Did you do anything to the front suspension? I imagine the LS1 is probably the same as or lighter than the staright six it replaced.
Is the stock hood going to fit?
