6.0L in 70 nova
Old Aug 11, 2005 | 05:54 PM
super nova's Avatar
Default 6.0L in 70 nova
I plan on putting a 6.0L from a 2002 chevy pickup into my 1970 nova, my question is, If I dont use the transmission, and use a TH400 instead will the swap and original harness work or do I need a aftermarket harness, if so where can I get one. Also how hard would it be to hook up autometer gauges to this style harness. and does the pcm need input from a speed sensor because obviosly I don't have one, also how about the ignition. how would that come to work
thanks
Old Aug 11, 2005 | 06:12 PM
79ls1's Avatar
You can use the factory speedo line and put a auto meater gauge on it and get the pin out for the rest of the gauges on the site.as for the the ingition your 6.0 will need coil packs and the cpu will control it triming the harness is alot easyer than it looks. Im a rookie and I did my own.
