95 K1500,5.7 To Ls1
Old Aug 16, 2005 | 04:25 PM
chuckk's Avatar
Default 95 K1500,5.7 To Ls1
I am trying to put a ls1 in a 95 k1500 4X4 w/a 98 4l60e are there any wireing harness adaptors ,motor mount adaptors anything that will help get this change over done as this is my daily driver.any help or advice would be greatly appreciated
Old Aug 16, 2005 | 04:26 PM
chuckk's Avatar
LS1 is out of a 2002 firebird
Old Aug 17, 2005 | 10:07 AM
LS1GMCTruck's Avatar
Thumbs up LS1 Into 95' Truck Swap
First...Buy another vehicle to get around in. The swap takes quite a bit longer than you might think. No, there are not any harness "adapters" available for this swap(that I know of). Most harnesses that are available, or the modification of your standard harness, will be of a "stand-alone" configuration. You will want to have the computer reprogrammed to delete & modify quite a few things, such as: tire diameter, gear-ratio, speed limiter, transmission shift points, vehicle anti-theft(VATS) removal, rear oxygen sensors deleted, EVAP delete, etc...Motor mount adapter plates that bolt to the LS1 block, that allow you to bolt a standard small-block GM three bolt, mount to, are available from Street & Performance...or you can make your own easy enough. The standard GM mounts can be bought at your local auto parts store. The standard F-body oil pan fits in the truck fine. Gar
