4.8/5.3 questions?
Old Aug 22, 2005 | 10:27 PM
The Guy in MY 99TA's Avatar
Default 4.8/5.3 questions?
I can get my hands on a 4.8 engine and on the block it has the numbers 4.8/5.3 casted in....... so whats the main difference the stroke? If so does the 5.3 have the same stroke as the 5.7?
I'm asking b/c I'm sure this block is good(it had a knock but had good oil pressure) and I have a set of good rods and crank and I can use my 5.7 heads and I already have a camshaft and everything. Heck for 200 bucks it should be worth it, it comes COMPLETE, intake, coil packs and wires, balancer, water pump, and a flywheel.
Josh S.
Old Aug 22, 2005 | 10:44 PM
hals73rs's Avatar
You can take a 4.8L, bore it out enough, and everything from your 5.7L will fit. Yes, 5.3L and 5.7L have same stroke. However the cranks may be different. Mainly it's the rear seal surface that is sometimes thicker on a 5.3L.
Old Aug 23, 2005 | 10:58 AM
Andy1's Avatar
4.8 stroke = 3.268". 5.3, 5.7, 6.0 stroke = 3.662". 4.8/5.3 blocks are the same bore @ 3.780".
Andy1
Old Aug 23, 2005 | 09:50 PM
StickSS's Avatar
Hi: There were some posts about this topic in the internal section. You might want to to a search for it. From what I read if you rebore the 5.3 block to 5.7 you have to use a 5.7 ls1 crank, rods and pistons to keep the engine in balance. If you mix and match parts or use aftermarket rods and pistons you would have to rebalance it. If you have most of the parts then I say go for it. You have to figure the cost of machine work too. Good luck.
