Header lengths? for UK enthusiast!
Old Aug 24, 2005 | 10:51 AM
Uk Robert's Avatar
Default Header lengths? for UK enthusiast!
I`m not far away from starting my LS1 in Ford(Mercury) Capri. It`s currently got year 2000 f-body exhausts which fit unmodified exactly right in the car. However I actually now have the money to pay a specialist to make up a set of headers specifically for my application. What is the ideal length of the primaries and collector tubes for an LS1... rough dimensions are all I need to get reasonably close and fitting "long tubes" (because they are much longer than normal??) seems to be the best exhaust modification. Thanks.
Old Aug 26, 2005 | 07:53 PM
WILWAXU's Avatar
Lets try this in the Hybrid section.
Old Aug 27, 2005 | 02:06 PM
Uk Robert's Avatar
Cheers!
Old Aug 30, 2005 | 06:26 AM
magius231's Avatar
https://ls1tech.com/forums/showthread.php?t=139142
check out the Exhaust Science Demystified section by David Vizard
Old Aug 30, 2005 | 04:52 PM
Uk Robert's Avatar
Thanks for the link
Old Aug 31, 2005 | 04:34 PM
GTS346's Avatar
If your engine is going to be pretty much standard, save your money use the f body cast iron junk if it fits.
Just go twin 2 1/2" from there back and you will only be down 5-10HP max in the top end.
However my engine I needed to make my own pipes as no standard ones would fit, I went 1 5/8" primaries, 2" secondaries and 2 1/2" collectors.
