GN fuel sender
Old Aug 28, 2005 | 08:16 PM
Oreo's Avatar
Default GN fuel sender
Hey guys, where can I find a fuel sending unit less pump that will fit my Grand National tank in my 86 cutlass. Dealer can get one at approx. 300 bucks. Can I do better, aftermarket?
Old Aug 29, 2005 | 01:52 PM
G-Body's Avatar
sawzall wielding director
No one makes aftermarket. I searched for ever for my El Camino. fortunantely your car takes a fairly common sender I think check the hollander interchange, I think it is the same for the GN as other g-body v6 cars. The cutlass,monte carlo, regal, grand prix and others were all available with efi V6 engines, and had EFI capable senders. Try rockauto.com or www.gmpartsdirect.com for a new one, gmparts has GN senders w/o digital dash for 200 and montecarlo efi v6 senders for 118. Do you already have a GN tank, I think a monte carlo tank is a bolt in and the senders are easy to find used, also cheaper new.
Old Aug 29, 2005 | 11:09 PM
6.0 mcss's Avatar
Try discountautopart.com The fuel sending unit you need is 140 bucks or at least that is what it was for my monte carlo.If you need anything else pm me have all those part numbers.
Old Aug 30, 2005 | 08:41 AM
redmist's Avatar
Summit sells senders for about $79
Old Aug 31, 2005 | 10:23 AM
88SS LS1's Avatar
I have one that I need to sell only thing is that the fuel gauge sender is not on it, did not come with it. But I have the entire sender with fairly new pump.
