AC question..
B DK GRN/WHT PCM 43 A/C Clutch Relay Control
C DK GRN PCM 18 A/C Clutch Status
I would think I would need 3 pins, one for AC request, one for the relay to trigger, and one for the relay to give power to the compressor.
Any thoughts?
my conversion:
http://www.fastblackcar.com/RX7/after/temp/
PCM
C2 pin 17 AC request from hvac switch (+12 volt is on)
C2 pin 14 A/C refrigerant pressure sensor signal
C1 pin 45 A/C +5 volt reference for refrigerant sensor
C2 pin 57 A/C refrigerant pressure sensor ground
plus the two already listed for the a/c clutch
So what we have is this
AC button to C2 pin 17 AC request from hvac switch (+12)
ground side of relay coil to PCM 43 A/C Clutch Relay Control
I am guessing the wire for the AC compressor is somewhere in those front harness connectors, ill find it and it will go the the switched side of the relay (i assume this goes +12, the clutch is grounded all the time and needs power..)
that should do it.
