a/c bracket
Old Sep 12, 2005 | 08:43 PM
yodawagon's Avatar
Default a/c bracket
i have the 02 ls1, from a camaro. that a/c is way too low to fit. will the corvette mount relocate it to the cylinder head?will everything just bolt right up?
Old Sep 12, 2005 | 10:55 PM
patrick_rodgers's Avatar
The stock Corvette compressor is in the same place (slide back a tad).
There have been discussions about relocating a different compressor or using a smaller one in the stock spot.
Old Sep 12, 2005 | 10:58 PM
joelvette's Avatar
s&p has a setup that mounts it up on pass side head.
Old Sep 13, 2005 | 12:50 AM
yodawagon's Avatar
s + p? thats got to be pricey!
Old Sep 13, 2005 | 07:28 AM
'JustDreamin''s Avatar
I'm sure S & P is not what you'd call a "budget option".
Which means you've got a couple of remaining options:
1.) Ditch the AC completely (not necessarily practical, depending upon location).
2.) Figure out a way to hack space for the existing AC compressor (may require Significant hacking, chopping, and welding on your existing frame / crossmember, again may not be practical).
3.) Build yourself an AC compressor mount to suit your location needs (clears frame, hood, whatever else you've got to work around, but this will depend upon your fabrication skills being good enough and having some equipment).
I haven't seen too many other setups for relocating the AC compressor....But you're welcome to search the web and see for yourself.....
Obviously, you're going to have to make the decision as to which of the 4 options you pick. Money, time, skill, safety, and vehicle value will all play roles.....Good luck.
'Dreamin'
Old Sep 13, 2005 | 09:04 AM
FastKat's Avatar
I'm particularly interested in using a smaller one in the stock spot... anyone have any input on that? (could perhaps require a little modification of the stock bracket as well)
Old Sep 13, 2005 | 09:07 AM
Try this thread https://ls1tech.com/forums/showthrea...ghlight=sanden
