1991-1994 cruise control setup
Old Sep 21, 2005 | 04:23 PM
2001CamaroGuy's Avatar
Default 1991-1994 cruise control setup
Need a little help.....
I'm in the process of finishing up my Fast XFI swap in my camaro and I want to use the "old" 1991-1994 F-body cruise control (is the 1991-1992 caprice/truck cruise control the same as the 1991-1994 F-body version?) because I read it does not have to "talk" (like the LS1 version does) to the factory ECU (which is no longer in the car). I also understand that it uses the same cable end as the LS1 (so it should be a direct swap).
Could someone give me the pin outs for how to wire this up (ie: the pin out order on the modal its self)? I'm still using the stock F-body steering column (with its stock wires in place) but ALL the "intermediate" wires in the car have been removed (full rewire).
Anything I need to keep in mind when I do this?
Thanks guys
Old Sep 22, 2005 | 05:47 PM
ok....update.......
I went to the dealership this afternoon in search of some part numbers and this is what I came up with as far as F-body Cruise Control modules:
1990-1992 = 25111869 ($192)
1993 = 25140793 ($89)
1994-1997 = 25140793 ($89)
98 = 25177447 ($110)
99-02 = 25315081 ($110)
so WTH is going on here?
this is why I really need someone to give a little more info......the part numbers seem to say there is one module for 90-92, one for 93-97, one for 98, and then one for 99-02? WHICH ONE DO I USE?!?!?!?!?
Old Sep 23, 2005 | 10:48 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The 90-92 F-body isn't electronic so you don't want that one.
I don't know the part numbers on these things well enough to know for sure. Check on a 91 Caprice or a 90-91 pick up truck. I know those are the good ones.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
