what do these wires goto...?
Old Oct 5, 2005 | 04:24 PM
slowassta's Avatar
Default what do these wires goto...?
Blue Connector on 98 Harness
Pin........Wire Color..............Sensor
25................BRN...........ECT Sensor Ground
49................YEL............ECT Sensor Signal
the harness i bought does not have a connector on it
i was thinking its the engine coolant temp sensor, and where does it plug into
Old Oct 6, 2005 | 09:16 PM
jdperk-86elco's Avatar
Look at the top thread "LS1 FAQ" it has harness and pin information listed.
Old Oct 7, 2005 | 12:56 AM
digitalsolo's Avatar
It is Engine Coolant Sensor, it plugs into the coolant sensor, which is located just forward of the exhaust manifold on the driver's side head. As I understand it, with a two wire, the pins should be reversable, but if you pick up a generic plug (AutoZone has them, it's just a "GM Coolant sensor plug"), the black wire with the white line is the ground side.
