Problems with a S10 v8 swap..
Old Oct 17, 2005 | 05:38 PM
mikes02ls1's Avatar
Default Problems with a S10 v8 swap..
Putting a carbed 350 in a 98 S10. It has long tube headers made by hedman for this swap, problem is the motor mount plates to use and what company. What part number for the motor mounts and plates. Sorry did my search and just didn't see what i wanted. Oh the truck used to be a 4cyl.
Mike
Old Oct 17, 2005 | 07:42 PM
dcdime's Avatar
Headman makes some mounts.. not sure if they have anything for the 2.2, you can call them and ask, it might take a simple mod to work or they might make them, just not showing them in JEGS.
Old Oct 19, 2005 | 05:33 PM
ZZ4Blazer's Avatar
Bolt holes on the crossmember should all be the same for whatever motor mounts. My 94 truck was a 2.2, and I bolted up the 2.8 style mounts without any problems.
All of the longtubes I"ve seen made are all POS. Goodluck getting those to fit. You will HAVE to get the recommended motor mounts/plates Hedman calls for to get them to fit even decently well.
Old Oct 19, 2005 | 05:43 PM
98TA_vert's Avatar
Just give Jegs a call I believe they use TransDapt mounts, Thats what they sent me and it worked, call just to make sure though.
Old Oct 19, 2005 | 08:17 PM
dcdime's Avatar
the newer trucks must be.. i know the 1st gen isnt.. the 4.3 trucks/blazers had pedastools for the engine to mount to... the 2.8 actually bolted to the frame, without the pedastool. ..
Old Oct 21, 2005 | 06:48 AM
s10-den's Avatar
hooker has a set of longtubes and mounts.the bach tube wraps around the frame.some dont mind some do.you WILL have to change the the 4 banger mounts
