chevelle steering shaft
Old Oct 27, 2005 | 07:40 PM
350SS's Avatar
Default chevelle steering shaft
6.0 transplant into a 72 chevelle. I'm flipping the exhaust manifolds upside down to run a single turbo setup. Unfortunately the steering shaft interferes with the drivers side manifold at the u-joint part of the steering shaft. I tried to clearance the steering shaft but the amount that I have to remove is way too much and I already went through the wall of the joint that contains the u-joint, grease, etc.
Anyone have any suggestions on what I can use to replace it with something with more clearance that I can utilize the stock rag joint and will fit on the splined end of the steering column?
Old Oct 27, 2005 | 07:51 PM
hugger 6933's Avatar
look into a borgenson[spelling?] joint lot of racecar places should have them a bunch smaller than the u-joint on your shaft. jim.m
Old Oct 28, 2005 | 10:59 AM
350SS's Avatar
exactly what I'm looking for, thanks
Old Oct 28, 2005 | 04:43 PM
5.3 racer's Avatar
if the borgeson is too large in diameter try sweet manufacturing.
Old Oct 28, 2005 | 05:34 PM
ls1_chevelle's Avatar
2002 Camaro manifolds tuck tighter to the block. Might want to take a look at them. I had to use them to clear my frame rails. The difference was about 3 inches when installed normally.
-Matt
Old Nov 6, 2005 | 07:30 PM
Formulized94's Avatar
i had to use the 00-02 fbody manifolds also on my swap. they seem to work well
