? LS6 motor mount
Old Oct 31, 2005 | 08:18 AM
jdeuel87's Avatar
Default ? LS6 motor mount
I am in the process of mocking up my drive-train. Putting LS6 into '67 Corvette. What do I need to do as far as motor mounts. Do I use stock LS6 block mount and then adapter plate to frame or is there another set-up for this? Where can i purchase conversion mounts if needed? Will I be able to use Corvette "bat wing" oil pan or will I need to go with Camaro type pan? ...Thanks, John
Old Oct 31, 2005 | 07:55 PM
72ChevelleConv.LS1's Avatar
don't think the bat wing pan fits. try ebay for a ls1 to old SB mounting plate they will be like Street and performance's.they bolt up to the LS6 block which is exactly like the LS1s block too.
