T56 + Carbed LS1 = ?
Old Nov 2, 2005 | 11:20 PM
Deckhand's Avatar
Default T56 + Carbed LS1 = ?
Hey guys my dad is looking into getting a 67 Chevy c10 Pickup, and hes going to use my old 4.8L LS1 motor for it. We are thinking about converting it to a carbed setup and mating a T56 for it. What would be needed as far as electronics are concerned for the trans since there will be no PCM? Speedo, etc?
thanks!
Old Nov 3, 2005 | 12:30 AM
1bad70+94camaro's Avatar
wondering the same thing but about the 5.3 with carb.edelbrock has a setup but i think its overpriced,but if it works really good then it would be a bargain.how the hell did you get your truck that quick in quarter?low 13 sec range with 4.8,man those ls1 cars cook!
Old Nov 3, 2005 | 02:51 PM
Deckhand's Avatar
4.8L has hotcam, tune, longtubes, full exhaust, 3000 stall, 4.10 gears, and a small shot of juice.
I'm gunna stab a 6.0L with a vortech sq trim blower soon, so we'll see how that goes.
Old Nov 3, 2005 | 02:55 PM
i have a few firebird bodies laying and might do a 4.8 or 5.3 install just to see how it would run.Dwmn quick truck u have there.Have u seen the turbo 6.0 4wd truck that runs in the 10 sec range and is street driven?I think his name is parish and am sure he is a member on here.
Old Nov 3, 2005 | 04:10 PM
dogger's Avatar
how are you getting totaly away from the pcm? you still have eletronic igntion to deal with correct? the t56 deosn't requrie a pcm it does have a digtial out put that you have to have a signal converter box to adapted to your speedo but other then that your good to to go. btw nice project. I am working on a 69 c20 but I'm not sure what I'm doing with the drive line. I'm probly going ot stay tradtion'll small block or big block with a four speed. I am realy been looking into swaping in a duramax diesel though but cost wise I'm probly not going to do it.
Old Nov 3, 2005 | 04:28 PM
70 LS1's Avatar
Conversion master
The T56 has 2 electronic controls. The 1-4 skip shift that can be left disconnected, and the reverse lockout solenoid. The reverse lockout requires a 12V signal and ground and energizes to allow reverse.
Old Nov 3, 2005 | 04:33 PM
Strokinit383's Avatar
On the reverse lockout, is A or B the positive side?
Old Nov 3, 2005 | 08:55 PM
70 LS1's Avatar
Conversion master
B is 12V and A is grounded through the ECM.
Old Nov 3, 2005 | 10:54 PM
It doesnt have to be grounded through the ecm though correct? If its a ground it shouldnt matter right? Im wiring mine to a constant 12v switch so that i can turn it on and off, so i could ground the A straight to be the body. Correct me if im wrong. Sorry for being off topic.
Old Nov 4, 2005 | 07:51 AM
70 LS1's Avatar
Conversion master
That is correct. Just ground pin A when you want to go into reverse with either a toggle or maybe a button on the shifter.
Old Nov 4, 2005 | 11:24 AM
Deckhand's Avatar
http://www.sdpc2000.com/catalog/3541...ld-Package.htm
Old Nov 7, 2005 | 10:34 AM
89lx-ls1's Avatar
I just connected my reversr lockout to my brake switch so if i wanted to go to reverse you just have to hit the brake. I just grounded it constant and the positive side went to the brake switch powerout to the tail lights.
Just some more info
