383 LS1 in a 91 RS
Old Dec 19, 2001 | 11:24 PM
beamar's Avatar
Default 383 LS1 in a 91 RS
I own a 91 camaro RS with the 305 TBI. I just bought a LS1 engine. I'm planning on rebuilding it to a 383 stroker. I already have most of the stuff. My questions are:
1) has anyone ever installed a ls1 in a 3rd gen. I also have the 4L60E I plan on useing. Will all of this go right in? Will my drive shaft work? Or will I need a new one?
2) I haven't got the computer and wiring yet. Where is a good place to look for that? also, There anyway to get my 91 RS wiring to work? I will prob need to re-porg the computer because of the 383, whats the best route to take on that?
3) I still need a cam. What is a good STREET cam, I want allot of torque and this motor will be all engine. I plan on using a stall(around 2500). I also don't want to pay in the $400 dollar range. I'll take a used cam if I can get one cheap. Should I go with bigger rockers? Not sure what the stock size is, just looking for a cheap way to get some torque.
4) still need a crank. I don't want anything special, just a cheapy around the $200 range. Which ones work, Do i need a 1 or 2 piece seal?
5) I need a flywheel. What do oyu think would be a good one, remember, don't want to spend a lot of money. I'll even take a stock, so if anyone out there replaced theirs with a lighter one and want to sell your old one, let me know.
6) how many CC's are the stock heads?
Think that covers most of it for now. thanks for your help
Old Dec 20, 2001 | 06:57 AM
RyanJ's Avatar
SSU Moderator
Default Re: 383 LS1 in a 91 RS
[quote]Originally posted by beamar:
<strong>3) I still need a cam. What is a good STREET cam, I want allot of torque and this motor will be all engine. I plan on using a stall(around 2500). I also don't want to pay in the $400 dollar range. I'll take a used cam if I can get one cheap. Should I go with bigger rockers? Not sure what the stock size is, just looking for a cheap way to get some torque.
</strong><hr></blockquote>
You -may- want to read up a bit on the LS1 before attempting the swap. New cams are always in the $400 range and cranks are more like $2000. Also, the LS1 has a different bore/stroke than a std SBC (3.989/3.622 v. the old 4/3.48) and since the aluminum block can be bored more than .005 or so building a 383 will be an all-stroke affair.
You should look into building a 383 SBC, not a Gen III LS1. They will have the prices you are looking for.
Ryan
Old Dec 20, 2001 | 10:42 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Give me an hour or two. I have a friend in Wisconsin who installed an LS1 into a IrocZ. He has a T56. He did it himself and I know he had to deal with stuff like the fuel lines, regulator, etc. He will totally help you out!
Old Dec 20, 2001 | 02:15 PM
LS1Tech Co-Founder
Webhandle: LS1 IROCZ
Email: LS1IROCZ@hotmail.com
Website: http://bradkiel.FBody.com
Car: 1987 Chevy Camaro Z28 Yellow
Engine: LS1
Trans: M6
He has a new website the link is in the old one....
Sample pic...
http://www.fbody.com/members/LS1IROCZ1/016.jpg
[ December 20, 2001: Message edited by: Pro Stock John ]</p>
Old Dec 20, 2001 | 05:50 PM
CRASH 02's Avatar
There is girl here that happens to be a friend of mine who is running a LS1 with a 4L60E in a 92 RS. They had to have Ed Wright do some changes to the computer to make it work. It was a Vette motor, computer, manifolds, a Camaro tranny new driveshaft and stock rear. That motor had the sticking valve in the oil pump problem wich equated into a blown engine. <img src="gr_images/icons/mad.gif" border="0"> She now has my motor from my toatled 01 T/A. She just got the heads back from a mild port job. I am trying to talk her into buying a small came from crane. It is a lot easier to get a race in that car than my 02 WS6.
