dimensions of ls1 engine?
Old Apr 16, 2002 | 08:04 PM
rg42284's Avatar
Default dimensions of ls1 engine?
What's the dimension of the ls1 engines found in the corvette compared to the ones found in the camaros? Compared to the lt1's which is taller, and wider? Are the transmissions the same size as well? Thanx
Old Apr 16, 2002 | 09:19 PM
John B's Avatar
Moderator
Default Re: dimensions of ls1 engine?
The LS1's are the same dimensions in either car. The LS1 is about 1" taller and wider (measured at the outer exhaust manifolds) than the LT1.
