Does the ecm use oil pressure?
Old Apr 26, 2002 | 04:30 PM
70 LS1's Avatar
Conversion master
Default Does the ecm use oil pressure?
I want to pull out the oil pressure sending unit and replace it with the one from to 70 corvette so I can use the stock gauge. Does the ecm use oil pressure for anything? Will disconnecting it cause any codes?
Old Apr 26, 2002 | 06:08 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Does the ecm use oil pressure?
If you are using a Camaro program (throttle cable), then no, the oil pressure sensor does not go to the PCM at all. If you are using a Corvette program (electronic throttle), then the oil pressure signal DOES go to the PCM, but it is not used for any engines running functions. The signal is sent to the PCM, then converted to a digital signal so it can be sent out on a serial data line to operate the dash gage and to send the data to the Driver Information Center. If unhooked on a Corvette, it sets a code but never turns the check engine light on. In either case, it's fine to fit your own sending unit so that your gage reads properly.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Apr 26, 2002 | 06:27 PM
70 LS1's Avatar
Conversion master
thanks, I am using a 99 Camaro computer so it should work fine.
