Somewhat successful start of the 70 vette
Well anyway, she started right up and ran for about 15 seconds and shut off. It did this several times which tells me I am not meeting the VAT device. I had built a VATs module to simulat the signal, but apparently it wasn't good enough. I am going to recheck my schematic to make sure I wired it all correctly.
Just to be sure, the '99 F-body uses the 5 volt, 50 Hz signal, right? If any of you have made your own VATs simulator, lets compare notes. I am sure it is something simple.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
<small>[ May 07, 2002, 10:41 AM: Message edited by: 70 LS1 ]</small>
www.speartech.com
Let us know how it works out.
www.speartech.com
For me there was no one resistor that bypasses the VATS. I built a 5V 50Hz signal generator and wired it to the PCM. I made it about the size of a zippo and it is removable so I can take it with me.
If you need to build one, let me know. I still have the schematic.
This link and another link for a VATS bypass schematic are in the FAQ sticky post 13. https://ls1tech.com/forums/showpost....1&postcount=13
