Alternator Conversion? Need Part Number?
Old Jul 7, 2002 | 02:20 PM
LS1GMCTruck's Avatar
Default Alternator Conversion? Need Part Number?
Am converting the front mounted accessories from a 2001 Camaro SS LS1 to the Vette accessory arrangement, which includes the Vette Alternator. Anyone know what the 2001 Vette Alternator Part number is??? Question? Will the Camaro harness plug right into the back of the Vette Alternator? Thanks in advance! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 8, 2002 | 09:04 PM
ls1sonoma's Avatar
Default Re: Alternator Conversion? Need Part Number?
This is what I used when I converted mine 10246634 I'm pretty sure it just plugs I don't have the harness back yet so I'm not 100%positive.
Old Jul 8, 2002 | 09:33 PM
70 LS1's Avatar
Conversion master
OK, I have to ask. Why do you have to change your alternator just because you are using corvette brackets instead of camaro brackets?
Old Jul 10, 2002 | 03:37 PM
ls1sonoma's Avatar
The corvette and F-body brackets have different spacing between the mounting holes. The power steering pump and crank pulley are also different so I needed everything.
