MACHINE WORK REQUIRED FOR LS6 INTAKE ON A 6.0?
Old Jul 25, 2002 | 08:27 AM
dream1q's Avatar
Default MACHINE WORK REQUIRED FOR LS6 INTAKE ON A 6.0?
i REALIZE THE TRUCK INTAKE WONT WORK, BUT IN ORDER TO PUT A LS6 INTAKE ON WILL ANY MACHINE WORK BE REQUIRED, OR IS IT A DIRECT FIT? i WILL BE USING THE ALUMINUM HEADED 6.0 LITER AND i WANT TO KEEP THE HEADS.
Old Jul 25, 2002 | 01:25 PM
John B's Avatar
Moderator
Default Re: MACHINE WORK REQUIRED FOR LS6 INTAKE ON A 6.0?
The LS6 intake uses different coolant lines underneather it to clear the larger plenum volume. You can either machine the intake ridges on the bottom to clear the LS1 lines or just buy the proper LS6 coolant lines and your good to go with no machining!
Old Jul 25, 2002 | 02:20 PM
dream1q's Avatar
eXCELLENT, I ASSUME THE COOLANT LINES FOR A LS6 ARE CHEAPER AND EASIER THEN THE MACHINE WORK, SO TO BERGER CHEVY I GO <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 26, 2002 | 01:38 AM
ls1ac's Avatar
I used the reverse, put 6-lt. on the ls1.
I had to use the truck water pump and alt. brackets to clear the intake.
Do not know if the opposit will be required for you.
Old Jul 26, 2002 | 01:40 AM
ls1ac's Avatar
Also had to make brackets to use 98 high flow injecters.
Old Aug 3, 2002 | 01:39 AM
N2TRUX's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ls1ac:
<strong>I used the reverse, put 6-lt. on the ls1.
I had to use the truck water pump and alt. brackets to clear the intake.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Can you give more detail on this set-up? I am having Texas Motorsports put a 99 LS1 into an 82 C/K Blazer, and want to use the 6.0 intake. I really want the taller manifold for looks primarly, but I am hoping for torque gains too. I don't understand why you would need the truck water pump and alt brackets to clear the intake. Can you please explain?
<small>[ August 03, 2002, 01:40 AM: Message edited by: N2TRUX ]</small>
