thoughts on my exhaust plan....
i hae a few questions on the exhaust setup im planning to run (not fitment issues, so it should be common for all ls1 cars)
in any case, im running the stock vette headers for now, until i get everything situated in the engine bay.
i plan on running an offroad Ypipe with a single 3in Random Tech Cat, 3in pipe, and a 3in inlet/exit magnaflow muffler.
my questions mainly pertain to the O2 sensor placement.
now ive got the two upstreamers plugged into the headers, and im about to order a wiring harness for it.
question is what should i do with the downstream o2 sensors.
ive ordered a tap/efilive/ and ls1 edit for tuning as well.
here in MD, we just have a sniffer test, and a simple visual just to make sure oyu have a cat underneath, and as long as i have one cat on, i shouldnt have any problems passing, especially considering an LS1 runs alot cleaner than the jeep 4.0 its replacing.
so basically id like a recommendation on an off road y pipe, and what to do with the downstream o2s.
thanks guys]
~John
I'm not an electronics wizard (although I play one on TV), but I would imagine that the leads could just be pigtailed together and go to the same sensor.
