Early bronco LS1 question
Old Nov 10, 2005 | 06:21 PM
dawater's Avatar
Default Early bronco LS1 question
I want to put a 5.3/6.0 or LS1 in my early bronco ('70). I've found an adapter to mate my bronco transfer case to a 700r4. I know that a 4l60e is basically an electronically controlled 700r4. My question is--are they close enough that I can use a LS1/auto combo (from camaro or 2wd truck) in my bronco with just a transfer case adapter for a 700r4?
http://eshop.advanceadapters.com/com...=1131666801984
I think it would take a lot of money to upgrade my 302 to EFI and LS1 power, not to mention the weight savings and cool factor...
Thanks in advance for your help.
Old Nov 10, 2005 | 06:59 PM
Camaroz's Avatar
Try PMing Gray (BigBronco) I'm sure he could tell you I hear he pretty much knows everything about em
Old Dec 3, 2005 | 03:04 AM
zz4bronco's Avatar
Default bronco
I just finished zz4 350 into bronco. You need to be concerned with overall length of 700 and 4L60.We replaced dana 20 with atlas because we were told it was to weak for chevy power.Driveshaft angle is critical with longer 700.I also have a 72 shortbed with 5.3 vortec in it with 4L60 I like the motor far better than zz4.
Old Dec 3, 2005 | 03:13 AM
zz4bronco's Avatar
I AM NEW TO LS1TECH, I REPLIED TO YOUR QUESTION IN WRONG AREA.I HAVE A ZZ4
350 IN 75 BRONCO.I HAVE A 5.3 IN 72 CHEVY SHORT BED WITH 4L60. THE 5.3 WOULD BE INCREDIBLE IN BRONCO.YOU NEED TO BE CONCERNED WITH DRIVESHAFT ANGLE WITH LONGER 4L60 AND THE 700.WE USED TURBO 350 WITH ATLAS II TRANSFERCASE
BECAUSE OF LENGTH ISSUES.zz4bronco@yahoo.com
