ls1 radiator
Old Dec 3, 2002 | 01:56 AM
capone's Avatar
Default ls1 radiator
i am swaping an ls1 into a 69 camaro. i was wondering if anyone has adapted the stock ls1 radiator to a 1st gen camaro, or any car for that matter. if so, how did you do it?
Old Dec 4, 2002 | 12:08 AM
68LSS1's Avatar
Default Re: ls1 radiator
I guess the easiest wat to answer that would be if you could get some measurements of an LS1 radiator and compare dimensions to yours. Are you looking to drop it in with out any modification or are up up to some more (as I'm sure the LS1 swap wasn't a "drop in"!!) Are you trying to get the radiator with the OEM fan setup? I'm going to use a Ron Davis radiator. They can build it to your original radiator size, add a core or two, add any LS1 stuff you might want and you can get a dual electric fan setup. They're aren't the cheapest but are one of the best.
